Welding mild steel to stainless using steel wire.
How can I find information on any ill effects of using steel welding wire to join mild steel to stainless (304)?
It is not a highly stressed application, but I would like to know if the weld joint would be effected. Weld corrosion is not a problem as the parts will be painted. I don't wan't to have to switch to a stainless wire in the middle of an operation.
RE: Welding mild steel to stainless using steel wire.
We weld pipe and plate as is where is with nothing other than the normal prep for welding. We use this in the procedure to qualify welders for SMAW welding of S/S.
Thanks and regards
Sayee Prasad R
Ph: 0097143968906
Mob: 00971507682668
email: sayee_prasad@yahoo.com
The black holes of nature are the most perfect macroscopic objects there are in the universe: the only elements in their construction are our concepts of space and time.
