hardness tests
hardness tests
hardness tests
The hardness at http://business.fortunecity.com/rowling/167/LARCSI.html is shown as “23-27 R ASTM E384-89.”
I am assuming that the "R" is Rockwell R, which cannot be measured by ASTM test method E384 (Knoop, Vickers).
Perhaps the measurements were made in accordance with ASTM E384 and then translated into what they thought was the equivalent Rockwell R value.
Is there a formula for converting Vickers to Rockwell R?
RE: hardness tests
Try ASTM E 140
RE: hardness tests
Thanks very much ijzer but the conversion tables in ASTM E 140 don't cover Rockwell R (60 kgf, 1/2" ball).  Anyone else know of a conversion?
RE: hardness tests
I further checked and found that Rockwell R is used for plastics only , so you will not find a conversion to Vickers
RE: hardness tests
I don't have access to it, but if you do, check out ASTM D785.
