Cable corosion protection
My application need to resist against salt-spray see-coast environement.
The machine is complete maded in stainless steel 316L. So the problem is about the electrical part. Which precaution should I take to avoid maintenance for many years.
The machin also have a lot of terminal, PCB Controler board,  fan heater, relay power supply circuit breaker, drive motor...
thank a lot,
RE: Cable corosion protection
Pierre;
Will the following link help?
Within some, you can get further and more specific answers.
http://www.azom.com/SearchResults.asp?AppKeyWord=Corrosion+protection
