Motor Rated Circuit Breaker for 160KW motor required
I want to refurbish my motor feeder for 160 KW motor. Due to space limitation in the feeder, I want to use some smart type motor rated circiut breaker or motor starter. Can somebody tell me where can I find it for such a large motor.
RE: Motor Rated Circuit Breaker for 160KW motor required
What voltage, current, etc? What is your size constraint?
http://www.thomasregister.com
and type Breakers: Circuit under Product or Service, which will return 186 companies to approach to
