NACE H2S Upper Limit
I have searched this topic and I can't find the information.
Question:
Is there an upper concentration limit for the NACE MR0175?
Example:
I can see that for carbon steels Rc22 is the max hardness to operate in the SCC zone as depicted by MR0175. But the charts in MR0175 show a limited pressure range and concentration range.
So - would I still be good with this standard if I know that I would be operating at 50% H2S at 10,000 psi?  It would definately be in the SCC zone, but would the concentration and the pressure affect the Rc22 rule?
Please advise.
jackboot
RE: NACE H2S Upper Limit
I have been involved in much SSC testing of steels for oil/gas production.  The upper limit hardness is a function of pH and H2S concentration.  There isn't much published on this.  Since steel with 22 HRC hardness can withstand 100% H2S (e.g. testing according to NACE TM0177), you should be okay with the 50% concentration.
Cory
Thanks for the information.
