Thrust Block Design
Thrust Block Design
I need information about the thrust block design procedure. In one side I have the momentum formula, and in the other side I have this formula T=2PAsin(phi) where “P” is the pressure, “A” is the pipe cross section area where the flow goes, and “phi” is the bend angle. Is the last formula a "rule of thumb" for the thrust block design? Using this formula, an engineer calculated 10 concrete trucks to build a thrust block for a 45 degrees, 48inches, vertical bend, and using the momentum formula I get only 2 concrete trucks for the vertical thrust block. The pressure (P) that he used was an assumed value equal to two times the working pressure for this pipeline. The working pressure for this pipeline is 150psi. So, at the end, the engineer is multiplying the working pressure by four!!
I know... I know. To design a Thrust Block I have to use the momentum formula and take in account the weight of the bend itself and the water inside the bend if it's a vertical thrust block, but I am a little confused with the engineer using that formula.
I'll be grateful if someone of you show me an example on how to design a vertical and horizontal thrust block.
Thank you for your information.
RE: Thrust Block Design
Andy Machon
Your answer to my request looks good, but where exactly can I get the information in the CIRIA's website? :(
ATT: Michael Troche, P.E.
Andy Machon
