Are fine threads preferred when vibrations are present
In application where an agitator is secured with bolts in tapped hole, should fine threads be used (rather than coarse threads)? i.e., aren't they less likely to loosen due to smaller incline angle?
RE: Are fine threads preferred when vibrations are present
