lighting Design
lighting Design
lighting Design
Is there any website or any one can providing a free ebook about lighting design (indoor, outdoor, industrial...etc), I need information  and examples about lighting design.
Thanks in advance.
RE: lighting Design
thank you,I  browsed the above sites and I got good information but if we assume that we have a building with 4 flates or a factory what type of calculation we must do and which formulas must be used.
RE: lighting Design
Use zonal cavity for indoor applications and iso-footle for outdoor applications. There is a lot of free software available from hundreds of light fixture manufactures . Contact your local lighting rep or search the web by brand.
 You need to know a little about the footcandle requirements for different occupanies. Try getting this information from the IES site. They charge $300 for there guide book but it cover most applications. If your a rookie try looking in the local library for any IES books on lighting or any books on lighting -there are hundreds of them. IES offers courses for certification to do lighting. Try them first. Lighting is not that complicated but it is intentive and require a lot of imperial know how. That is where the IES comes in they set the standard for lighting like the NEC does for electrical construction.
Anybody can just stick a light some place and that will work-maybe. But if you are a professional and want to do design work then try courses and the IES.
Finally-The local lighting representatives will offer free calcs if you use there products and that is what a lot of design people do.
RE: lighting Design
Question to Rizgar (Electrical)    Dec 9, 2003 marked ///\\\
///Please, what kind of information have you obtained, specifically?\\\
///There is software available for free if you are interested to perform the lighting calculations by yourself. The software is easy to use. It is just necessary to become familiar with it. The above posting already suggested how to approach to the calculations, and an alternative, to contact the lighting fixture manufacturer representative for the major support. There is also IES Lighting Calculation Handbook. It sells for over 400US$.\\\
