ANSI Pressure rating/testing?
I'm looking to pressure-test fittings manufactured for the vacuum industry but I'd like to show that they have been pressure tested by an outside source. This info may be useful in the case someone wants to weld them to a pressure system they can pursue ASME stamps on their own but at least they know these products work under pressure.
Is there such a service where products can be pressure- rated/tested by an ANSI certified company? Is the above even of any value to someone seeking ASME certification?
Sorry if I'm not seeing the bigger picture here. I'm very new to this and am looking for a starting point. Thanks for your time.
RE: ANSI Pressure rating/testing?
Br
Berni
