Tesselation lines in a drawing view??
Im creating views onto my sheet (wormgear shaft), and for some reason, the 'end' views are displaying this line from the center mark to the edge of the page. I cannot seem to delete/hide it.  Are they tesselation lines where tangences on a particular point dont quite line?
RE: Tesselation lines in a drawing view??
Don't hide it delete it. There was a bug in SW04 SP0 that inserted a centermark from the origin to the center of the file. The only way to get rid of it is to remove it and re-add it. Otherwise upgrade to SP1.
Scott Baugh, CSWP
3DVision Technologies
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
Actually thats not the problem (i have sp1 anyway). I dont think it has anything to do with the centerline. It just happens to place a line (which i cannot even select), from the center of the part, to the edge of the page.  Looks like a kite with the string leading to the corner.
i had this happen twice both times the drawingwas corrupt in that sometimes i could open it and work quite fine on the drg.
then after a while i tried to open the drawing and it just said the drawing was corrupt howebver when i recreated the part and dropped it into the drawing it was a ok
i also tried replacing the sheet, if its the same thing does the line extend from the ctr of a view to a corner of the sheet or from the ctr to corner?
if so it might be the same thing
