Autocad N Excel
Autocad N Excel
Autocad N Excel
ok so i figured this much out if i have a nice spread sheet in excel that i want inserted into acad as acad entities to make a table of sorts how can i take that info from autocad back to excel does anyone know
if everyone helps everybody the world will be a better place
RE: Autocad N Excel
I use OLE OBJECT to handle the EXCEL SPREAD SHEET.  One problem you may have is setting the font correctly.  At best ACAD handling of OLE Objects is fair.
