maintenance plan for gas turbine generator
hi people.u have been doing a great job here on this site.
i need some information on the maintenance programme for a gas turbine generator unit.
our company,currently has four gas/diesel powered turbine generators,with a network of back up diesel generators.the turbines are named European Gas Turbines,EGT, manufactured by RUSTON and the plant is about 20years old.the problem now is that the availability of power from the plant is very low.this has given us a lot of concern.in my country,there are no other firms that have this kind of turbine.
what i need is information from you guys,especially those that have worked in the power generation industry on the appropriate maintenance program that i can implement to improve the availabilty of the turbines.i reall will be grateful.thanks
RE: maintenance plan for gas turbine generator
They still support the earlier turbines (Typhoon, Tornado etc.).
http://www.asme.org/igti/services/pubs/paper_archive/co...
etc. for more info
Also, check:
Stewart & Stevenson Services, Inc.
2707-T N. Loop, W., P.O. Box 1637
Houston, TX 77251 1637, USA
Tel: 713-868-7700
Fax: 713-868-7692
Assets: 250M+ (over $250,000,000)
Employees: 1,000 Or More
Activity(ies): Exporter
Company Description
Engineered Diesel & Gas Turbine Power Systems
http://www.industrial-turbines.siemens.com/en/servicesd...
for: info on Maintenance Packages
