Measuring Tape 16"
Measuring Tape 16"
Measuring Tape 16"
Hello all
There is a distinct mark (Either an arrow or a dot)in addition to normal markings, every 16" in a commercially available measuring tape. What does this indicate?
Does 16" stand for some old measuring units?
RE: Measuring Tape 16"
I believe it is for spacing studs when framing buildings at 16" on center.
That is exactly it, 16" on center is a standard framing dimension in the US.
Correctomundo, 16" is standard stud spacing for residential housing construction in the US. For commercial I believe you can use either 16" or 24"
Roy Gariepy
Maintenance and Reliability Dept.
Bayer Corporation  Dorlastan Fibers Div.
Goose Creek, South Carolina  USA
OOPS, Like sms states it is for framing in general (US); rafters, floor joist, studs etc., etc.
Roy Gariepy
