Exporting images to Word
Can anyone tell me an efficient way to export an image of a Pro/E object into a format that can be inserted as a picture into an MS Word document? I am interested in transfering both shaded color images and black and white drawing type images, and need to strike a balance between file size and picture clarity/resolution.
RE: Exporting images to Word
For shaded images, do the following:
Change the blended background with a solid color(not used on the components) / or white color
Be sure the main window is activated and press ALT+PRTSCREEN
Paste the image in word and CROP and SCALE it to the right dimensions. You can use the "Remove background" tool to make the background transparent or you can let it white if you have the white color background.
For drawings, the best format is CGM (vector based). Save the drawing in CGM format AFTER you changed the system colors to BLACK on WHITE.
Good luck
-Hora
For drawings, exporting as TIFF file works fine too.
im4cad
Pro Design Services, Inc.
http://www.cadproe.com/pds/home.asp
I use a program called "Snag It" to window exactly what I want and export it to the file type I want.
http://www.techsmith.com you can get a 30 day trial from them.
Besides my use of "Snag it", Hora is right on.
JOSE FIGUEROA JR.
Matt
I never heard of HIJAAK before.
But the idea is there.
Going the other way.
Insert-object (or ALT-I-O) will get you files on a Pro/E drawing.
JOSE FIGUEROA JR.
I'm talking about 2001.
im4cad
We are not re-inventing the wheel. Just skip some steps like "save as file" and then "import" it. Why do you need to keep the garbage on the disk when you can use the windows clipboard? And it's faster in this way than your method. Save as... type the name, import the file in word (somemtimes tkes minutes to see where the jpeg was saved).
I agree with Matt and others for a better Windows screen capture to reduce the size of the file.
-Hora
im4cad
ProEpro
www.whitelightdesign.com
Pro/E FAQ www.whitelightdesign.com/servicestips.htm
