Crash log
Crash log
Crash log
I've created an assembly that uses variables to create new sizes.  About 1 out of every 5 times I do a size update, SE V14 crashes and I have to restart.  Where do I find the crashlog that's generated each time, and can I do anything with it to determine the cause of the crash?
RE: Crash log
Do a search on your harddrive for "crashlogf.txt"
It is usually somewhere in the documents and settings/local settings/temp folder for your current username.  If you have maintenance with UGS, then you should file an IR and can upload the crashlog file to help them determine the cause of the crash.
--Scott
For some pleasure reading, try FAQ731-376
RE: Crash log
Thank you..problem solved
