Vane Axial Fans
Vane Axial Fans
Vane Axial Fans
Has anyone used a vane axial fan in a forced air duct system?  We are planning to use a fan in the flow path of a heat exchanger on board an aircraft, that also sees dynamic pressure due to flight.  Under what conditions will the fan overspeed?
