NFPA 850 and 20 numbers of jockey pump ?
As I understand demand from NFPA is :
1 main electrical pump (primary)
1 main diesel driven pump (secondary/standby)
1 small jockey pump (only 1 pump is enough ?)
RE: NFPA 850 and 20 numbers of jockey pump ?
About the jockey, I´ve seen that in general for power plants a 3hp electrical listed pump is commomnly used, but I don´t know how it is sized from the possible leaks spected as the NFPA 20 recomends.
rgds
The concern is if the primary water supply is lost, i.e. water main break, power failure the facility will have fire protection.
Brice FRANC
SPK Engineering
http://www.spk.fr/Protection%20incendie/Securite%20ince...
