Auger Cast Pile Design
Does anyone know the basic design methodology for auger cast piles?  Is it strictly an end bearing calculation, skin friction, or a combination of the two?  To determine end bearing capacity, would you use the Neely formula of ultimate unit end bearing capacity = 1.9 N where N is SPT value of the bearing strata?  Also, to determine pile capacity, would the formula be .25Fc x Area of Pile?  Thanks for the help!
RE: Auger Cast Pile Design
Please see the other post in this section from Nov 25.
