Step-down pressure of demin water line
I am looking for options to reduce the demin water pressure from a 8 barg header to about 5 barg for a downstream process unit. The downstream unit has been designed to work with a low pressure rating and there is a relief valve set at 5.5 barg. Anybody got any sugestions on what can be used to do that? Thanks.
RE: Step-down pressure of demin water line
Do you need to reduce the operating pressure? Are you trying to prevent the PSV from opening?
I don't know what your flowrate is to the lower pressure system but a control valve would be a pretty common solution. The dP across an RO will vary as the flow rate changes. The dP is likely too low for a hydraulic recovery turbine. We really need some more information on your system and what you are trying to achieve.
