wear rate coefficient
Hi there
I have posted before but couldnt get an answer. Desperately need a K valve ( wear co efficient) for Steel upon steel * sae 4140 against Sae 1040 - I not sure of the 1040, I am assuming here.
I need to estimate the waer on a rotating rod
The Hardness of the 4140 is in the region of 131 brinell and a surface texture of N8 .
I just need an approx ansew to know if the design stands a chance.
There is a garranteed star in it !!!!
Stephen
Stephen
RE: wear rate coefficient
Next I'll see if I can find some actual coefficients for you.
As promised . yes I am terrible like that I know what I mean to say but others and I leave info out its a big problem for me
Yes I had intended to harded the 4140 so I had hard on soft ..would the similar percent carbon have any effect??
Stephen
WOW Temperature is between 20 deg and no more than 40 deg c the pressure 4.3Mpa rotational speed 400 rpm and the lubricant is a grease oil ( ep90 ) mix THAT sometimes penetrates hence calling it a boundry lube prob. the grease mix is a very slap dash arangement.So I am try to judge differing materials and shapes etc
Stephen
Anyway, as you probably already know wear is usually one of 2 types-adhesive or abrasive. With similar metals you frequently get adhesive wear problems. Dirt in the grease gets you abrasive wear (simple, huh?).
Now, we need to know what diameters are involved here, so the RPM gets meaningful.
I don't think the similar C level of your 2 steels means anything at all. Once you harden the 4140 the C will be distributed in a completely different manner--in fact, nearly all HT of steel can be thought of as an alteration of the way C is distributed!
If you can, consider something like nitriding the surface of the 4140-the harder the surface, the better, and nitrided surfaces seems to slide better than many other surfaces.
The formula I am using is depth of wear D equals
( force x Length) divided by ( hb x Area) all mutiplied by K co efficient of wear...
But this wear fiddle factor is very vague and I cannot find any
The nearest I came was bronze on steel at 0.001 to 0.01 x 10to the power of -15
it gives me a wear depth after 1725 hrs of use at 400 rpm
of 2.9mm
Seems a liitle low to me ..
The dia of the shaft is 7.5 mm and it bears against a either a ball bearing OR a rounded shaft of 6mm dia
I want to go with the ball bearing as I can keep the shafts short and any missalignment can be LOst as it were
Once again thanks
Stephen
