Welding White Cast Iron in Sulphuric Acid Service
We have a submerged pump casing with a minor pin hole through a web section. The casing is submerged and in hot sulphuric acid service.
I have spoken with the manufacturer who is not keen to advise on the material propoerties other than it is made of a white cast iron. They have also advised that the material is "unweldable" which I find hard to believe.
As the pump casing is only four years old and the defect appears to be from a localised alloying concentration, as the remaining pump casing seems fine, I am keen to try a localised weld repair. Does anybody have any advise on suitable weld methods, consumables and welding parameter control etc.
RE: Welding White Cast Iron in Sulphuric Acid Service
This alloy is termed nonweldable. However, if you insist on trying to fill up this pinhole defect,you may try a high Ni welding rod. This will fill the pinhole but the properties will differ as you are filling with a soft material. There will be no fear of cracking etc.Alternately putties are available with different grades of filler metals which you can try. Hope this helps.
Drill and tap the hole to 1/8" pipe thread.
Install a threaded plug.
If temperature is too high then plastic is not suitable as a plug. I am not sure what alloy plug would be suitable, but 1/8" pipe plugs can be obtained in many alloys and one could easily be custom made from the correct alloy, even the identical white iron alloy.
PUMPDESIGNER
Does the pump manufacturer use or have 1/8" plugs or perhaps 1/4" plugs available in that identical alloy that perhaps they use in their manufacturing?
PUMPDESIGNER
