Swimming pools
Swimming pools
I have (the design of) a hotel and a swimming pool on the roof and another one at the ground level in front of it.
The upper pool and utilities are covered by a glazed dome, the lower pool is "outdoor".
Can you please tell or point out the relative NFPA 72 requirements for both locations?
Thanks!
Thanks!
RE: Swimming pools
Elecme
RE: Swimming pools
The devices should be listed for use in damp areas (gasketed).
I do not think you need any fire alarm devices for the 'outdoor' pool or any outdoor areas are covered by NFPA 72 for that matter.
Also look up building codes addressing the swimmig pool areas which would direct to applcable fire codes.
RE: Swimming pools
