Bonded-Bolted Joint Design
Does anyone know how can I get a copy of "L.J. Hart-Smith, Design Methodology for Bonded-Bolted Composite Joints"?
RE: Bonded-Bolted Joint Design
This seems to be a paper from Wallops, AFWAL-TR-81-3154.  Try contacting their library, or NASA's technical report server (NTRS).
STF
L. J. Hart-Smith authored several articles for ASM HANDBOOK Volume 21 Composites, including, I believe, the section on Bolted and Bonded Joints (pp.271-289).  I am not 100% certain because my copy is at home (where I frequently need it?).  Perhaps you can find a copy of this volume in the reference section of a University engineering library, or you can try ordering only this article from the ASM Library:
http://www.asminternational.org/Content/NavigationMenu/...
