lost command line
lost command line
lost command line
I cannot seem to get my command line back.Any help?
Bart1
RE: lost command line
Hi Bart,
wich version are You running? How many (command-)lines do You use?
I think Your line slid behind the taskline... Move it...
Lothar
Make the screen size bigger and see if that helps. For example, if it's 768 x 1024, make it 864 x 1152.  You should be able to see it now.
Flores
Hi smcadman...
Make the screen size bigger, sometimes that not works. But it is valid.
Un saludo de SpeedCAD... :)
CHILE
FORO: www.hispacad.com
