Hi all, I have designed a tempor
Hi all,
I have designed a temporary steel grid over a pit which will be plated over. From the beam spans that I need and designing for a 200 psf live loading,I have arrived at a maximum beam spacing using S6 x 12.5 members.
My question is now, how do I calculate what thickness of plate to use. Obviously,the greater the beam spacing,the thicker the plate would have to be. Thanks in advance for any help.
RE: Hi all, I have designed a tempor
