Application.OnKey(Key, Procedure) "Hot Keys"
This is a great method... but of course I ran into some trouble.
Application.OnKey(Key, Procedure) sets up hotkeys, for example if you would like "Shift & Cntl & F" to run a sub you would code...
Application.OnKey "+^{k}, "MySub"
I'm using this to show and hide a form as needed.
It works great while excel is the active window... but when the Userform has focus the key combo is not recognized.
The code is currently in my workbook.open event I've tried placing it in the userform activate event as well... but no luck...
Any ideas???
Thanks for the help!!!
Any ideas???
Have a great day!
Scott
