Need Example source
Need Example source
Need Example source
Hello Forum,
I'm a programmer and have to implement some funcions in C or C++ for MathCad. Can someone send me a short code example? (How must a funktion be implemented, if I want to use it in MatCad...)
Best Wishes
Peter
RE: Need Example source
Every Mathcad installation comes with example functions in C.
Additional information can be found in the e-book on programming for Mathcad.
Finally, there have been several examples of fairly complex DLL's programmed for Mathcad in the Mathcad Collaboratory, although you'll need to do a bit of searching to fnid them.
TTFN
Since it is not apriori knowledge, you might be wondering how to find the Collaboratory referred to in previous post.
Collaboratory can be found at :
http://collab.mathsoft.com/~mathcad2000/
Actually, for Version 11, at least, the Collab is directly accessible from within Mathcad by selecting the "User Forums" selection on the Help Menu.
TTFN
@jOmega, IRstuff: Thanks for your help
Best wishes
Peter
