150KV Line Voltage Drop
Dear All,
My friend has problem on 150KV trasmission line about 100km's voltage drop to 120-130KV.
The qustion:
- What is the main cause of this problem usually..all of lead, tower and distance are under rating
- Is there any technic of installing capacitors to correct the voltage drop on HV system..?
- Or is that any corellation between Main step-up transformer that installed at the power plant site..?
Thank you for your kind attention and help.
Eskim
The qustion:
Eskim
RE: 150KV Line Voltage Drop
Review of a good power engineering text such as Stevenson, "Power Systems Analysis", may be helpful.
Power transfer is not specified, but voltage drop is so significant that a voltage/load profile study by an experienced firm would likely have a fast return on investment.
