WBLOCK AUTOCAD2000I
WBLOCK AUTOCAD2000I
having trouble with wblock in some drawings. No error giving but won't write block to drive. Does not occur in all drawings, sometimes it works, sometimes it dosen't. Any solutions to what is causing this problem?
RE: WBLOCK AUTOCAD2000I
"Whether you think that you can, or that you can't, you are usually right "
.. Henry Ford
