kinematics/linkage
kinematics/linkage
I am looking for software to solve relatively simple linkage problems. I am only really interested in load transfer through the system, but displacements and velocities would be nice. Currently, I set up traditional member analysis in MathCad and solve for the result. This works out ok; however, I have found that mathmatically there are often many solutions to these systems and sometimes it is difficult to distinguish the real world result. I have seen ProEs'motion/load solver, but I prefer to not build a 3D model just to solve a system of equations.
Thank You,
Mark
Thank You,
Mark
RE: kinematics/linkage
Why not just do it the "old fashioned" way. You might even end up re-educating yourself in the process, and be better able to judge the adequacy of what the computer spits out the next time.
PS I have done the problem by hand--that is why I know that my mathcad document is funky.
Thank You
I had pictured the problem from the other direction, though- use the geometric tools in smartsketch to convert input lengths, geometric constraints, etc., into a picture of your geometry, then export key angles, positions, etc., for further calcs in Mathcad. Like a fancy, parametric, free body diagram.
Check out the FAQ Resources for Mechanism Analysis and Synthesis (FAQ404-804). As you are a Pro/ENGINEER user, I suggest taking a look at SyMech (www.symech.com) as it will do what you need and have the ability to actually synthesize mechanisms. I have had good luck with using a combination of the MDX functionality with the Behavioral Modeling (BMX) features for solving mechanism problems as well.
Best regards,
Matthew Ian Loew
"Luck is the residue of design."
Branch Rickey
Thanks for the tip.
Mark
