Interfacing Shell and Solid elements in ANSYS
I am trying to model a steel Box girder with concrete deck in ANSYS by using the Shell element for girder and solid element for deck. Is there any recommend way to connect the interface between 6-DOFs shell(Upper flange of girder) and 3-DOFs solid elements(bottom surface of deck) without inconsistence?
I will appriciate for any comments from you.
looking forward to hear from you.
RE: Interfacing Shell and Solid elements in ANSYS
Main Menu>Preprocessor>Coupling / Ceqn>Adjacent Regions
in the GUI.
The best of luck,
-- drej --
Regards Sven
