Adding Material listing to BOM (2000i)
I have assigned parts in an assembly a material type (setup, material), now I would like the material to be displayed on the BOM. Is material a system parameter? Here is a listing of my current BOM:
.breakdown
%$type %$name contains:
.titles Qty; Name; Type
.row %$quantity[-5d]; %$name[-32s]; %$type[-11.11s]
.summary
Summary of parts for assembly %$name:
.titles Name; Qty ; Thick ; Width ; Length
.row %$name[-31s]; %$quantity[-3d]; %D1[-3.3s];%D3[-3.3s];%D4[-3.3s]; %$material[-3s]
mfg
.breakdown
.summary
mfg
RE: Adding Material listing to BOM (2000i)
What I think you need to do is the following:
the %$material should be %material
Let me know how you get on, as this is the first time I have looked at this and may need to know a bit more in the future.
Hope this helps.
maybe only a drafter
but the best user at this company!
You should add the following relation to each part if you want the material to be displayed on a BOM:
material = material_param("bend_table")
Be sure you have the material description on the "bend table" parameter of each material. No spaces allowed.
NO, material is NOT a system parameter.
-Hora
I setup the material and added the material type to the bend table. Then added the following relation to the part:
I also edited my custombom.fmt file as follows:
.breakdown
.summary
.titles Name; Qty ; Thick ; Width ; Length ; Material
.row %$name[-31s]; %$quantity[-3d]; %D1[-3.3s];%D3[-3.3s];%D4[-3.3s];%material[-9s]
Thanks for all of the help.
