Create a sheet through a solid
I need to create a sheet body cut through a solid. This cut must be done on a conic section (I have the conic face).
I've got one that I've done by creating a copy of my solid, then intersecting with the conic face. But this produces a disassociated sheet. (I need the association as I need to be able to ask each created edge from which feature has it been created from).
Is there any way (in UgOpen) that I can do this?
The function UF_MODL_create_section_surface "sounds" promising, but there's no info on how to use this!
Help much appreciated!
Steve
RE: Create a sheet through a solid
Can you extract the face you need (or a region) and trim your solid to that? An extract feature would retain associativity.
Thanks, that's almost there!
If I create using method above then the edges a get back are associated to the conic from which I extracted the face, but unlike on an intersection, when I ask the edge what faces it was generated from I only get the conic back. I need to find out which face of the "main" solid it also came from.
Any ideas?
Have you tried to intersect a face pair at a time?
