Member Login
HANDLE
PASSWORD
Remember Me
Forgot Password?
E-mail*
Handle
Password
Verify P'word
Partner With Us!
Partner Button
(Download This Button Today!)
Member Feedback
"...This was the ONLY place that I could find information that I could use to resolve the problem. So thanks once again to member TomSark and the SQL forum!..."
Geography
lyndsay4321 (Chemical)
26 Nov 03 10:06
I am currently solving a problem where i am pumping heavy oil from a vented to atmosphere storage tank, through a heat exchanger and along mild steel pipe to furnace where it is then atomised.
Could anybody please recommend a reasinable density to use for this heavy oil, and also if anyone knows what the roughness ratio is for a steel pipe, and how this varies with pipe sizes of 0.25 to 3 inches (0.6cm to 7cm)
thanks
TD2K (Chemical)
26 Nov 03 11:03
You really should get this from the company you are doing this work for.  When you say heavy oil, is this fuel oil or do you actually mean heavy fuel oil.
Fuel oil can be close to the density of water at 60F, you then need to correct that for your operating temperature.  Roughness of commercial steel pipe is commonly taken as 0.00015 ft, you then divide this by the ID.
TD2K (Chemical)
26 Nov 03 13:54
Opps, should have said "When you say heavy oil, is this heavy crude oil or do you actually mean heavy fuel oil."
25362 (Chemical)
27 Nov 03 11:07
For good mechanical atomization of liquid fuels, including asphalts, it is recommended that the fuel viscosity be less than 20 cS, well filtered. Some burners require pressures of about 110-120 psig.
Helpful Member!jmw (Industrial)
27 Nov 03 12:43
You should know that fuel oil quality is vary variable. What you may think you are burning and what you are actually burning may be very diferent indeed. Density, which you ask about, is one of the variables, viscosity is another and can have a serious impact on your design. Also, different parts of the pipe will be at different temperatures when you are before or after the pre heaters or in the final feed to the burners.
Your assumptions when designing should consider if this is a non-producer of fuels or hydrocarbons who is buying in fuel (where some form of quality control is theoretically possible, some surveys suggest fuel quality can vary significantly e.g. from 150 to 410cst for a fuel nominally of 380cst)or if you are in a refinery or petrochemical plant. In the latter they may say they burn commercial grade fuels but in my experience they often burn processing "mistakes" or the petrochem plant take the out of spec grades from their refining partners.
Density can vary of course, and for heavy fuel oils this varies from 975 to 981 kg/m3 for 10cst oils (density at 15degC and viscosity at 100degC) to between 991 and 1010 kg/m3 for 55cst fuels. Or at least, these are the limits according to the standards.
As 25362 says, these fuels are then heated to obtain the optimum viscosity for atomisation. This is a whole other area and if you need any information here, please say so and i will add some further comments but it would seem to be getting away from your original questions.
You need to discriminate between what the design standard is and what they actually have as a fuel. They should be able to provide you with daily fuel analysis results, or at the very least, with results of samples taken on individual bunkers supplied.
waydamo (Chemical)
10 Jan 04 14:19
You cannot guess or estimate the density as there is a large range of API that are called heavy oil.  You must obtain at least the density from your client.
chem55 (Chemical)
13 Jan 04 10:00
Canadian government has published Oil properties according to Location. You can refer this on http://www.etcentre.org/databases/spills_e.html
regards,
Chem55
Start A New Thread
Promoting, selling, recruiting and student posting
are not allowed in the forums.
Posting Policies
LINK TO THIS FORUM!
(Add Stickiness To Your Site By Linking To This Professionally Managed Technical Forum)
TITLE: Chemical process engineering Forum at Eng-Tips
URL: http://www.eng-tips.com/threadminder.cfm?pid=798
DESCRIPTION: Chemical process engineering technical support forum and mutual help system for engineering professionals. Selling and recruiting forbidden.
