ECU Connectors
ECU Connectors
Well as some of you may know, many aftermarket manufacturers of Engine Management systems have the stock vechicle's ECU connectors so that the customer can simply plug their new ECU into the stock harness, no rewiring required.
I have seen this done on more than one ocassion for more than one vehicle.
Does anyone have any first hand knowledge of where these very proprietary connectors are purchased from or where they can be found?
Your help is greatly appreciated!!!
RE: ECU Connectors
RE: ECU Connectors
Ideally it would be great to find a manufacturer who stocked or had ECU/harness connectors for most production vehicles.
At this stage of the game I just have a one-off need so I have decided to part out an unfortunatly working ECU for only the connectors, and also a stock harness for the male side of the connectors to make a pass through cable for which I can pull signals off easily.
Let me know if you have any futher info, thanks again!
RE: ECU Connectors
good luck
RE: ECU Connectors
Do you happen to know the scope of that family of connectors (which vehicles).
Lastly, how did you obtain this information, is there a reference guide or something similar out there for me to resort to in the future?
RE: ECU Connectors
Thanks in advance.
RE: ECU Connectors
Thank You for time on this.
RE: ECU Connectors
I have been told, but cannot confirm it, that it is a Ford part.
RE: ECU Connectors
It is 2003 Toyota Matrix, 1zz-fe.
Hybrid connector
E3 34pins (# pins in each row)7,10,10,7
E4 35pins 7,12,8,8
E5 35pins 6,10,11,8
E6 31pins 7,10,8,6
RE: ECU Connectors
RE: ECU Connectors
When I tried to locate these connectors I was unable to find any mfr or distributor with them in stock - they all required minimum orders with no samples available.
If anyone finds a way around this, please let us know, thx.
RE: ECU Connectors
Dan
Owner
http://www.Hi-TecDesigns.com
RE: ECU Connectors
Someone like Waytek might stock a few.
