Pro/E plugin does not work.
I've installed DS6 on 3 pc's. Two work, the third does not recognize the pro/E plugin.
I've followed the "ERRATA" sheet that came with DS6 concerning registering the dll. DLL shows as registered but, still no integration. No DesignSpace button in Pro/E and DS6 does not recognize the open pro/e model.
Subject pc is a Dell620 p3/1ghz zeon/win2k sp2.
Does anyone know what else could cause this problem?
RE: Pro/E plugin does not work.
program files\ansys inc \cad integration\proe. I would sugest you set up for 2001 as then any model created on pro21 can be read in.
