Concrete Slabs - how should they be joined
I am having a new larger conservatory built and I would like to know what is the recommendation for the joining of the new concrete base to the exsisting concrete base.
I thought a steel pinning would be required as I live in an area with subsidence, but the company doing the work says that this is not neccesary.
I would appreciate any advice
RE: Concrete Slabs - how should they be joined
IF THE STRUCTURES ARE ATTACHED AND DEPENDENT ON THE FOUNDATIONS PERFORMING AS ONE, YOU WILL HAVE TO LIMIT SETTLEMENT BETWEEN THE STRUCTURES AND DOWEL THE STRUCTURES TOGETHER. THE GOAL OF GAINING TOTAL HARMONY BETWEEN THE FOUNDATIONS IS NOT VERY LIKELY TO BE ACHIEVED, BUT THEY WILL BE CLOSE ENOUGH FOR MOST SITUATIONS. SITE PREP IS IMPORTANT TO ACHIEVE YOUR GOAL. HENCE IT MUST BE WELL COMPACTED AND ANY PIERS MUST REST IN THE SAME BEARING STRATA AS THE EXISITIN PIER.
GOOD LUCK.
Please see FAQ731-376 by VPL for tips on how to make the best use of Eng-Tips Fora.
You don't say how old the original base is - This may be relevant. You refer to a base - are we talking about a strip footing under the wall line or is the conservatory to sit on the edge of a ground bearing slab?
In either case the cost of inserting dowels cannot be significant. If you want them - get them.
Most PVCU conservatories come with a warranty. Check to see if this covers the foundations.
Glass is indeed a brittle material but this is probably of little relevance to the issue of foundation movement as the distortion will effect the PVCU frame first. The glazing units usually have a gasket seating which will accommodate all but gross movement. If you are expecting gross movement than the foundation solution is WRONG regardless of dowels.
We are not expecting any gross movement, just slight subsidence, the original base is twenty years old and is a ground bearing slab.
The cost is not the issue, just the company saying it is not required.
