power factor capacitors
ive got to do a survey of the capacitors on site for power factor say what size and what type ie oil filled paper pcb.i have the size but how do you distinguise whether they are paper etc.the make and type are MKP is this any use.
RE: power factor capacitors
One approach is contacting the capacitor manufacturer with can-label serial numbers.
http://www.capacitorindustries.com/
http://www.capacitorindustries.com/pdf/CMP%20data%20she...
http://www.cooperpower.com/Library/pdf/S2602010.pdf
http://www.bvws.org.uk/405alive/tech/pcbs.html
http://www.reynoldsindustries.com/product/7micacapacito...
http://www.capacitors-ez.com/capacitors/0046794_0060479...
etc. for more info
Hope this helps.
Best regards,
Mark Empson
http://www.lmphotonics.com
http://www.tesla-cap.cz/dokument/tc886_uk.pdf
for: MKP for motors
http://www.tesla-cap.cz/dokument/tc884a_uk.pdf
for: MKP for lighting
http://www.vorlac.com.au/searchres.cfm?select=7&subcode...
etc. for more info
Is there any consensus on the best approach?
I have some basic information on my website at http://www.lmphotonics.com that may be useful
Best regards,
Mark Empson
http://www.ccu2.org/docs/9925.pdf
http://www.ewh.ieee.org/reg/7/canrev/canrev33/adaptive_...
http://cc.ee.ntu.edu.tw/~thc/course_ckt/note/chap7.pdf
etc. for more info on the power factor correction
