Sprocket tooth profile
Hey guys,
I'm in a position where I need to cut a lot of sprockets. Of course, existing sprocket manufacturers aren't too keen on giving me the profile of the tooth, and I've had no luck google-hunting.
Can anyone point me to an information source for the correct design of sprocket teeth? The pitch is around the 8mm mark, approximately 50 teeth, 4-6mm thick, to give you an idea of the size I'm dealing with.
Col.
Col.
RE: Sprocket tooth profile
A…Standard roller chains / ASME B29.1
B…Heavy roller chains / ASME B29.1
C…Extended pitch roller chains / ASME B29.3
D…Standard roller chains (EU) / DIN 8187, ISO R-606, BS 228
E…Standard roller chains (US) / DIN 8188, ISO R-606
F…Extended pitch roller chains / DIN 8181, ISO 1275
G…Low speed sleeve chains / DIN 8164
H…Galle chains / DIN 8150
Mirekp
http://www.mitcalc.com
Mechanical calculations
