Help with a Find
Help with a Find
Help with a Find
I copied this find method from the Help file, modified it, and can't seem to get it to work. It returns the first "c" ($C$689 so I know it found it) but I can't get it to go there.  I want it to find PN and replace the cells to the right with other data.  What do I need to change?
Roger
    With ActiveSheet.Range("C2:C65536")
    Set c = .Find(PN, LookIn:=xlValues)
    If Not c Is Nothing Then
        firstAddress = c.Address
        Do
            Selection.Offset(0, 1).Select
            ActiveCell = COL_F
            ActiveCell = COL_H
            ActiveCell = COL_I
            ActiveCell = COL_G
            Selection.Offset(0, -4).Select
        Set c = .FindNext(c)
        Loop While Not c Is Nothing And c.Address <> firstAddress
    End If
    End With
RE: Help with a Find
After the Set c=.Find and the Set c=.FindNext, add a line c.Select
Cheers,
Joerd
