position sensor?
position sensor?
| have a frame of bays 5*4, that's 20 locations,and a robot arm that is moved in the x and y axis with 2 motor belts.
I want to control this robot.Do you have any ideas of how I can know the current location of the robot arm.
Many thanks for your help:)
RE: position sensor?
David Baird
dbaird@gemcity.com
Sr Controls Engineer
EET degree.
Journeyman Electrician.
<nbucska@pcperipherals.com>
1. If you control them with a computer-type device,then you should check out the small motor control packages.
"Encoders" are pulse-signalling devices which may be integrated into a motor assembly. The computer controll device will count pulses from each motor, and thereby can determine how far the device has travelled from a known reference point.
2. to control without computer (or maybe even with), use prox sensors or limit switches to detect when the unit reaches each point of interest.
let us know how it goes!
Jay
They have linear, optical scale encoders, which actually measure location on an encoded track, but they are a more expensive solution.
1)how accurate do I need to be?
2)how fast do I need to do it?
3)how critical is an error?
4)how often will this process change?
The successful selection of the best control (which may include position info) initially hinges on the basic requirements of your application. Control technology continues to be quite specific with selections made to accommodate the most pervasive constraints (hopefully well understood in the beginning).
you should also answer the following:
1. what kind of motors are installed on the robot?
2. will i use these motors?
3. what is my budget for motion control boards or plcs?
Or..
You could use twenty AND gates(one for each bin), with the inputs tied to the corrusponding row and column. The output of that gate would corruspond to that bin. This would tell you when you got to a particular bin, but may work well for navigation. If you hooked up a pannel of LEDs to the gates, you could get a nice visual. Or you could hook them up to a multiplexor and use the output to feed a computer.
