Brick Structures
Brick Structures
Brick Structures
I am in a municipality that still has a number of standards calling for brick structures such as: manholes, inlets, Y connections, bellmouths, etc.
I believe that there really isn't a need for these structures because precast can be made to accommodate any situation and generally is installed quicker and cheaper.
Further, I would say that there is no need to include them in standards anymore.
Any thoughts?
RE: Brick Structures
We do not use brick structures in any of our specifications.
Not only is precast (or cast-in-place) more cost effective, the leakage rate is lower.  In sanitary situations, this means lower treatment costs.
Many of the older brick structures are now having to be replaced, repaired, and/or lined.  The concrete structures have a longer lifespan in most instances.  The bricks hold up well; but, the mortar doesn't.
Just my 2 cents.
