Help with Snowmobile Catalytic Converter
The ASME chapter at our school is trying to retrofit a pickup catalytic converter to a snowmobile chassis. Can anyone direct me to a good resource for learning more about catalytic converters (i.e. airflow ratios, acceptable temperatures, warm up periods, etc).
Joe Friday
Joe Friday
RE: Help with Snowmobile Catalytic Converter
mpmidgley@aol.com
Ken
JoeFriday
(Will this be crankcase scavenged? oil injected? Metering oil and accounting for that in the air/fuel mix should be interesting...)
Jay Maechtlen
I ended up taking a magazine that did some turbo compressor map sizing calculations and figured out what I needed to know: the turbo's too big. Heh, so we have to go find a turbo for a 4 stroke snowcat somewhere cheap (we're all college students). Anybody want to donate? You pick a boost you want to run at, then calculate air density based on estimates of air temperatures, then calculate mass airflow based on engine size at various RPM's. Then you plot those points based on pressure ratio (pressure of air entering engine/absolute pressure) and a mass flow rate for your turbo's performance data. Turns out, anything under 3000 rpm would put the turbo in the "surge" region.
Thanks for the replies.
Kenny
What's the smallest car engine that was sold (in your country) with a turbo? I guess that's not entirely valid, 'cause the turbo needs to be sized for the right pressure ratio as well as flowrate...
Contact turbo distributors, manufacturers, and repair shops. Tell them about the project, and see if they might help you out.
good luck!
(of course, 'good luck' usually entails lots of planning and effort!)
regards
Jay Maechtlen
Kenny
