EXPAND/COLAPS SHORTCUT
THE DEFAULT SHORTCUT IS "C". I CANT SEEM TO GET IT TO WORK THO. ALSO, WHEN USING THE VEW FEATURES/DEPENDANCES SHORTCUT, (VERY USEFUL BTW) IT ONLY SEEMS TO WORK WHEN THE FEATURE TREE IS SPLIT, AND ONLY ON THE BOTTOM ONE.
ANY HELP, AND SUGGESTION ON OTHER USEFUL SHORTCUTS ARE WELCOME.
THANKS
'MATT
THANKS
'MATT
RE: EXPAND/COLAPS SHORTCUT
Until I figured out what they were doing. Expand/Collapse works ONLY (?) on the transparent tree that appears in the graphic window when doing something like a Edit Feature.
Try that, and it should expand/collapse....
Mr. Pickles
And fyi... caps lock does not effect shortcut keys.
Its about 115mb i believe...so im sure it has fixed something there.
Scott Baugh, CSWP
3DVision Technologies
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
Are you saying yours does not work either? My 2004 sp1 works on the transparent tree, like I mentioned above. Do you think it "should work" on the "fixed" tree also, like previous versions?
Mr. Pickles
