Nonlinear material properties
Hello.  Can anyone recomment a good reliable source for nonlinear stress strain curves.  What I need is mostly common steels, cast aluminum and other common engineering materials for use in FEA modeling.
Thanks.
RE: Nonlinear material properties
Do you mean stress-strain curves in the plastic (nonlinear) region, or do you mean for nonlinear-elastic materials?
Cory
Nonlinear in the plastic range, above the yield point.  Most of the materials that I would be interisted in have a well defined modulus of elasticity.
You could also contact a materials testing lab. they may have the ability to give you very hihg resolution digtal data from actual test specimens.
nick
