Re: the IPC 2000 Section 909 Wet
Re: the IPC 2000 Section 909 Wet Venting.
909.2 Question: In the second sentence, is the size of the dry vent intended to be equal to/a continuation of the diameter of the largest pipe? Or is it intended to be 1/2 the diameter, as sizing is intended between a waste and a vent pipe?
Concetta7
Concetta7
