Water Tanks
Water Tanks
Water Tanks
Does anyone have any guidelines for designing large capacity steel rectangular water tanks - sizes ion the order of 7m x 2.5m x 2.5m.
Ideally a set of standard calculations to demonstrate suitability of design with respect to material thicknesses.
RE: Water Tanks
Pressure Vessel Handbook by Megyesy ISBN 0-914458-10-8 has calculation procedures for rectangular tanks.  Alternatively, you can simply design it as plates and beams, the stiffeners welded to the plates would be the beams.  You will want to use stiffeners for weight efficient design; otherwise, your plates will get rather thick.
