expansion joint
expansion joint
how to design /calculate expansion joint loop in furnace of fire tube boiler .
we have fire tube boiler in which Lithium bromide+ water solution is on shell side .The furnace is non corrugated .There is differential expansion between tube and furnace .
can we give expansion loop on furnace instead corrugations .how to size it
please help
please help
RE: expansion joint
BS 1113 gives information on the requirements for expansion joints in furnaces as does AS 1228. I cannot remember if ASME I does. What design standard is your boiler designed to? I may be able to help.
Bogu
RE: expansion joint
To design expansion joint you can use EJMA expansion joint manufacture associate.
Also you can use the ASME SEC VIII appendix 26.
