Methanol Further Cooling
I want to cool methanol gas-liquid mixture after separator at 40 DegC to about 10 degC. The duty is about 15 GJ/h.
Does any body has idea how to do the methanol further cooling.
The reason way I want to cool are:
1. To remove as much as possible liquid carry over into downstram compressor (we have several time abradable seal damage du to liquid carry over)
2. To have additional methanol recovery (about 5.5 t/h for 10 degC cooling)
sgms
sgms
RE: Methanol Further Cooling
Although further chilling may result in more liquid methanol, apparently your main problem is liquid carry over to the recycle compressor. How do you propose to reduce this liquid carry over by further cooling the recycle gas ?
Isn't it more profitable to improve or re-design your vapour/liquid separating facilities ? Kindly comment.
Might by the sugestion form imok2 will work. we will work out on that proposal or you have in your hand..?
thanks
