Where can I find a Stainless Steel hydraulic jack?
I'm looking for a hand or foot operated SS hydraulic jack, long stroke, light duty (less than 1000 pound cap). Something like you would see on an engine hoist or a pallet lift. Much like a McMastercarr 2923T51. I may be able to use a SS cylinder and a SS hand pump unit seperates.
Thanks for the help.
RE: Where can I find a Stainless Steel hydraulic jack?
The Miller SA series ( see http://www.millerfluidpower.com/SA.pdf ) 303/304 stainless caps, cylinder, rod, aluminum piston, will handle clean air or petroleum based fluid up to 400 psi. I think they will also supply this with stainless piston. There are probably other models and/or vendors, but this one sticks out in my memory. A few years back I was looking for hardware suitable for water hydraulics (not 90-10, just water) and discussed this with Miller. Sizes range from 1 1/8 to 8 inch bores.
